If you have a 220vac three phase motor right now, and only have single phase, then there is a couple of options, buy a VFD, this gives you the advantage of retaining the superior 3 phase motor and also having variable speed control, or go with a 1ph to 3ph converter, no speed control but you could run other 3ph equipment off it. For practicle purposes 3ph motor cannot be rewound for 1ph.
Al
__________________ CNC, Mechatronics Integration and Machine Design.
Albert E. |
