Thread: Problem Okuma Cadet mate RS232
Old 08-04-2009, 06:25 AM
Superman's Avatar
Superman Superman is offline
Superman is on a distinguished road
Originally Posted by Colinneil View Post
I keep getting this alarm message #320 RS232 not ready when I try to download from a PC,I know it is connected correctly because I can use the DNCB ok, can anybody help?
Hi Colin, welcome to da zone
I assume that you can send files from the control to the PC with no problems.
Quite often the file that is to be transmitted requires a "%" at the end if the file to let the control know to terminate receiving mode, you may have to trial if the same code is required as the 1st line of code as well
What are the machine's comms switches set to, they are set differently if running a file thru DNC as opposed to sending a file to MD1:
Typical procedure for sending to the control
  • -on PC, open DNC program, select machine and transfer config
  • -on PC, select or open the required file
  • -on m/c, set comms switches ( if running DNC or just sending file )
  • -if running full DNC (R-method on m/c screen), cycle start should start program running
  • -if sending, <Edit>, <DNC-b>, <In>, Your Filename.MIN <Write> ---- you should be seeing the file being sent on the PC screen,--- the control screen will update or do a linefeed when entire file has been read into the control, if no % is at the end of the program <<<< the machine may freeze--- and require a reboot >>>>
Note!!!- comm switches when setting to R-method ( full DNC ) may only be recognised after a m/c reboot
And I don't think you can you "PIP" "READ" , but give it a try
