Originally Posted by niklasn78 i have check my head and if i move it i will move the hole trolle the small flex is the tollerense in the rollers on the guidelines.
and yes it is a wavy line i say it differ 1mm too each side in a wavy pattern. |
I was going to suggest that one or more of the rollers on which your head trolley might be damaged, non-circular, off centre, or have some dirt on it. However if there is slack such that the trolley can wobble, that is probably the problem. My machine, a different model, has some small screws that can be used to adjust this such that there is no play in the trolley. If your head/trolley moves in the X direction on the beam, there should be no play in the Y direction.
