  #11   Ban this user!
Old 07-31-2009, 01:00 PM
bocko912 bocko912 is offline
bocko912 is on a distinguished road
CHIP
I do have a manual that came with the machine. I am not at home currently so I am doing most of this from memory. I will be back Monday. You said there should be a air cylinder by the pulley's but I did not see any air lines coming out of the head.Only wires for the prox switch. I also need to check for a param's disk. The guy kinda messed up wiring in the cabinet trying to find a problem which turned out to be a bad 24 volt power supply. I will have to go through it and fix it up. Maybe I will find something disconnected. I did notice that he had the spindle brake disconnected. It must be bad I will have to check that also. I am sure that this is a fully functional Tchanger but I got the feeling that he messed around with stuff he should not have trying to get it to work. I have tried to operate the Tchanger with the M codes and machine will accept them but does nothing accept rotating the Tchanger. It just seems that the machine has the Tchanger turned off. Maybe he did that after he could not get it to work.
Thanks John
