Mach2 remembering position after shutdown..how does it know | | Hello guys.
I have the machine working.. have yet to set up home switches.
My question is:
After I have finsihed for the day I set the machine about in the middle. The DRO's note the position. After switching everything off and then re-starting Mach2 doesn't rememebr its last position and I have to re-set the Zero positions.
I know home switches tell Mach2 where home is, but...
But if you switch a machine on and it doesn't know where it is...how would Mach2 even know which direction to start looking for a home switch.
For example... if the machine was at the X+, Y+ extremes on startup and the DRO's all show Zero.... how does Mach2 know which direction to go?
Is there so way of locking the DRO's/position on shutdown?
cheers
Frans |
