Adam
Before you remove any parts or buy any items make a schematic drawing so you sure as to what you are doing. The basics are, p/s to motors identified by the two large capacitors, find output and check with meter should read around 70V dc. Identify motor and travel stop leads all the rest is junk. You need a breakout board and p/s and two motor drivers to take 70V and a VFD.
Follow instuctions with the parts you buy and understand them, if you are not sure contact the repective support. thats what they are there for. One tip put a low amp fuse on motor p/s output.
Good Luck
Mike |
