Originally Posted by ajclay WSS
Those cuts do look good for the thickness. You pulled the setting out the manual like Jim was talking about? Looks like your cutting table is heavy enough :-)) |
AJ, I have to be honest, I copied/pasted/printed Jim's post #6 and started at 80amps, and worked until I had "dross free" cuts as Jim recommended. I am not sure of the speed, as I am using an old pantograph with a vari-stat to control the speed, it turns from 0-100. The oxy could not cut above 50 (it would lose the cut in the corners) and the plasma sailed dross free at 65, but would cut at 75 with a little dross. I would estimate the speed to be about 25ipm, I have another 80 or so cuts to do on Wed. and I will time them and measure the cut to be accurate.
The table is an old acorn/platen lay-out table that is about 3" thick. It will be transformed back to a lay-out table when our Dynatorch is finished. It is kind of like a pair of shoes that don't fit, it will last forever!
