The MACH integrated THC logic lets you have a full Z axis for any type of cutting. By adding a cost effective DTHC module our Breakout/Interface product (MP3000) can turn the Z into a full interactive Digital Torch Height. You can switch from using Z for other 3 axis cutting, milling, drilling to DTHC in a simple profile change in MACH.
You can use your 4th axis to build a nifty rotary axis for pipe cutting! All you need is a full controlled XY and Z with separate motors and drives.
We have everything from board level products to full blown 5.5 axis stepper or servo controllers. You can buy in at any level of system.
TOM Caudle
www.CandCNC.com
Totally Modular CNC Electronics
