Setting Rouring dept on Jet130 | | Hi,
Thanks for the info, Can you help in that when I import a dxg/dwg into cnc editor,it defaults to setting all depths to zero. How and what would be the quickest way to set all lines to a specific depth. Instead doing it individually,tried find/replace function, but keep on having to click find next.
Also is there a manual for the genises software that explains in detail, all the programming techniques.
Hope you can help,
Thanks,
Brian. |
