Actually the paper method with very low power produces accurate results when compared to electronic based measurement system. It even shows the halo or HAZ (heat affected zone) around the focused beam.
You will of course need a sufficiently high mag scope with measurement capability to determine the actual spot size vs. the halo area.
I have not tried Alumamark but that should work the same way, just with more power required.
Zax. |
