I am now running SolidCam 2009 SP1 and I see there is an option in the CAM Setting page called Tool settings. If you select the Show in CAM Manager setting then you will get the tool number just above the operation name in the cam manager tree. Once you have this, you can then click on it to make changes to the feeds and speeds! This will then update all the feeds and speeds in the tree that use that tool. Still cant change the drilling cycle with out going into the interface! |
