Old 07-22-2009, 08:30 AM
Larken Larken is offline
Larken is on a distinguished road
The buzzing sound is the short ciruit protection circuit tripping out. You may have a bad motor, possible with a shorted winding to the frame or some other short. Check the motor that there are no metal chips(turnings) inside that cut into the insulation.
Its possible that you've blown a mosfet in the Z axis drive. The Mosfets are a IRFP4232 . Its best to change all 4 mosfets and the IR2104 drivers at the same time.
Or, I can send you a replacement board
Larry K
Manufacturer of CNC routers and Viper Servo Drives
www.LarkenCNC.com and www.Viperservo.com
