Thanks, I just found that through some searching, the bad is that the setup worked the way it is, now it doesnt. So Im assuming something has failed in that axxus board? I have no idea what some of that stuff is/does (the yellow boxes, and the little black box on the other side), but the motors all work and it follows the cut program fine, just doesnt light off the laser.
Yes, on the laser power supply box I can fire it and make it cut, but it wont follow the on/off of the program.
Say that axxus board is shot, what is a direct replacement youd reccoment?
Also, the laser control is on the aux output 17 with some little diodes? (not sure what they are)..
Couple more pics
