Old 07-21-2009, 02:04 PM
FanucIssues FanucIssues is offline
FanucIssues is on a distinguished road
cog belts that move when spindle changes direction
What would cause two 60mm wide cog belts to move when the spindle changes direction? Is it, as I assume, as simple in discussion as the motor, and the spindle are not on center? If that is the case how would you verify what direction either one needs to move? Too many questions: Spindle bearings also be a part of it? What are your thoughts?
It's not what you cut...It's what you don't cut.
