Old 02-09-2005, 06:37 PM
Hack Hack is offline
Wanna be
Hack is on a distinguished road
Yes that is correct
the way you are typing it in should work. If not, try typing sysedit instead. This will bring up all of your windows such as the autoexec.bat, config.sys etc. If the edit autoexec.bat command does not work, is it possible that you renamed the file something else accidently? Seen that happen before.
Check out what I am working on at www.routerbitz.com!
