Old 07-19-2009, 05:38 AM
dhenry dhenry is offline
dhenry is on a distinguished road
Smile Converting drawings to metric
MDF forms a surface skin when pressed. To machine 25mm to 19mm would seriously reduce it strength. You would better to use 18mm with a 1 mm spacer where needed or to convert your plans to metric. If you can get me full solidworks plans I will convert them to metric for you.
Originally Posted by rocket67 View Post
Hi Ger21, I have checked with our MDF supplier and found out that in Australia we have 18mm thickness.
The metric conversion of 3/4" to mm is 19.05. So we could machine a 25mm board down to 19.05mm, or as you suggest - change the dimensions to suit the 18mm board. Not sure which way to go yet.
Found another good thread which has a file for nested base cutting of the MDF board -
http://cnczone.com/forums/showthread.php?t=53757
Look at post no.2 from Joe.
For interested members, we will post more on this subject as progress is made.
Rocket
