Originally Posted by ChsBrown OK, I have the 6" KITAGAWA chock on the SL-10. It's only been on about three months. I can't get the drawtube nut to come loose. The operator's manual says the chuck has to be clamped,..... HELP!!!
PLEASE!!!!! |
Clamped as you should find out when you read my post that thum31 linked you to.
It can be a real pain unscrewing the nut because if you are not careful you round off the corners of the slots in the nut. The trick I have discovered is to keep the wrench held in firmly with the turret, but not too firmly otherwise you trigger a Z servo overload.
Good luck,
