Old 07-16-2009, 09:14 AM
keebler303 keebler303 is offline
keebler303 is on a distinguished road
If you are doing some fairly basic machining, you can use the wizards in mach to go directly from idea to cutting. There are some CAD programs with CAM "add-ins" so that it all works together. Can't give you a list but I know they are out there.
Drill chucks are for drilling! They are generally held together with a jacobs taper and are not designed to resist side loading when milling. Does the KX3 have a spindle which accepts tool holders or is it just a collet chuck (like ER16 or something)? Anyway, you will need a different collet for each size shank of bit. You probably only need a few to start, then you can buy more as you feel the need.
Matt
