WADKIN UX SERIES POST | | Hi there,
I've attached it as a text file.
When you get it to your pc change the file name from (.txt) at the end and put in .arp
Then you can open it in alpha edit as a post.
When it generates the program after the G4F4 take out the next line that says G0 Z10 and the program will run fine.
I've not taken the line out of the post because you need it when its pocketing.
When you are generating your program it brings up details about tooling and baseboards etc if you don't need then just go into post and amend them.
But it is useful to put info in for operator.
Give me a shout if you need more help
Shaun |
