Hi Al,
Thanks for taking the time to help me out.
Below are photos of two different units, 3 views each. I checked unit #1 with a volt meter and got 39.5 volts using the green and red wires and 26.3 volts using the red w/yellow strip and green wire.
I haven't checked unit number #2 for voltage yet, as the wires are not as easy to get to but will check it out if you want. These two units do the same thing which is to power an actuator that moves a satellite dish (big c-band) .The motor of the actuator on the dish was a 36 volt motor.I said 24 volt motor in my first post and that was wrong.
Steve |
