If you use I and J to specify the distance from start to center, you don't need a radius call out. I'm pretty sure your above example will not work (it will create a 3/4 moon shape). J.194 in the G02 block puts the center +.194 in Y from the start point. J-.194 in the G03 block puts the center -.194 in Y from the start point.
I would replace the J.194's with R.219's. I back plotted it and it worked fine with R's.
What alarm are you getting? |
