Originally Posted by Tuz Thanks for your reply,what will this tell me when I run that code? What am I expecting it to do?
I run can run a program like this: (Is this Helical?)
N20G55M3S18000X3.75Y2.75
N30G43H24Z0.25
N40G1Z-0.4F100.
N40G62G91G2J1.F200.
G2J1.F400.
G2J1.Z0.5F400.G61
G90X3.75Y3.125
G1Z-0.4F100.
G91G62G2J0.625F200.
G2J0.625F400.
G2J0.625Z0.5 |
I'm not a mill guy so I'm not sure what the G61 and G62 are doing but...
if these lines...
G2J0.625F400.(cut a circle using XY)
G2J0.625Z0.5(cuts the same XY circle while moving in Z)
then you have Helical and you "should" be able to do what you want.
Provided that the Sarting point A and Ending point B are valid starting and ending points along the selected plane at the given radius.
Good Luck!
