Thread: New Machine Build Plasma Cutter Feedback
Old 07-08-2009, 08:52 AM
jimcolt jimcolt is offline
jimcolt is on a distinguished road
Steve,
We introduced the FineCut consumables for the Powermax600, 1000, 1250 and the 1650 over 3 years ago.....that is technology derived from our high definition class plasma systems.
The 45 uses this technology along with a new conical flow torch design that does take this a step further....however it requires some slightly different output characteristics in regards to gas flow, current ramps, and timing to make it work at it best. There are no current plans to introduce the Powermax45 torch technology or design into the previous models at this time......
Hypertherm in the past has offered upgraded torch replacement kits as new technology was available....and I suspect there may upgrade available at some point in the future.
While this FineCut and conical flow technology is a great improvement to air plasma cut quality on thinner materials....it is not even close to competing with our HPR130, 260 and 400 in terms of high definition cut quality, speed and operating costs. The true high definition technology requires very precise gas flow control, current control, a liquid cooled torch, and a special vented nozzle design, as well as the ability to use oxygen as the plasma gas. These systems are high end industrial plasma's that produce high volume cutting with tight tolerances and very low operating costs......however they are usually out of the price range for entry level plasma system users!
Jim
