Old 02-05-2005, 06:55 PM
Davedbq Davedbq is offline
Davedbq is on a distinguished road
Ok guys here is where I am at.... I have managed to get only one axis in TurboCNC working even though all three axis are or seem to be set up exactly the same. In KCam3 I have two axis working and cannot find a menu to enable the missing axis to get it to work. Below is the pin settings for TurboCNC that I have found and set up but have not been able to figure out how to set pin numbers 14 thru 25 in TurboCNC. I have also tried Mach2 but not on the computer that I am currently working on as it is running Windows 98. When I ran Mach2 it crashed my computer so I gave up on trying to run it. Dave
> here are the pins.
> 2- [D0] bs OUTPUT x axis direction
> 3- [D1] bs OUTPUT x axis step
> 4- [D2] bs OUTPUT y axis direction
> 5- [D3] bs OUTPUT y axis step
> 6- [D4] bs OUTPUT z axis direction
> 7- [D5] bs OUTPUT z axis step
> 10- [S6] bs+1 INPUT z switch detect
> 12- [S5] bs+1 INPUT y switch detect
> 13- [S4] bs+1 INPUT x switch detect
> 14- [C1] bs+2 OUTPUT x axis *enable (active LO)
> 16- [C2] bs+2 OUTPUT y axis *enable (active LO)
> 17- [C3} bs+2 OUTPUT z axis *enable (active LO)
> 18- GND
> 25- GND
