Originally Posted by kanankeban 2. Im planning to use rack and pinion in x,y,z axis, don't know which one is better 14.5 degree angle or 20 degree, and I don't know either what kind of friction they impose on the system.
3. The weigh of the gantry, well, Im planning to do it from steel so it will be pretty heavy. the maximum speed for cutting is 240ipm, I'm building this table for a Hypertherm HT2000 High Speed Plasma.
The 20 deg. angle spur gear/rack takes a heavier load than the 14.5
Remember on a horizontally controlled axis, especially if there is minimum side thrust as in Plasma cutting, the maxim torque required is not at rest or at final travel speed , but at acceleration & deceleration (inertia calculation) for very good design information, check out this site and if you get their free library of catalogue, half of them is dedicated to Engineering topics.
http://www.sdp-si.com/D220/D220cat.htm#S1
BTW are you driving both sides of the gantry? At that weight you may need to.
Al
