There seems to be conflicting information on the web concerning the joining of rails. IKO makes specially end-ground rails for joining. While this may be important in some applications, it is not important with a router.
The tolerances just aren't that critical unless you are using heavily preloaded trucks and working at the upper end of the design load range.
As long as you use care when joining the ends you will have no problem. |
