The series 1 cnc[boss etc] iron is as rigid as you will likely ever need, much much more rigid than standard bpt iron. the universal kwik switch helps in this regard, much less chatter than 30 taper in my experience. at the very end, [explorer] the series one came with an extended travel , probably an extended leadscrew. |
