Old 07-02-2009, 04:52 PM
timlkallam timlkallam is offline
timlkallam is on a distinguished road
Hello Larry Theres two way to do this
On the work off set page the page with the G54(00) G54 G55 G56 G57 G58 G59 offsets . The very Frist offset the G54 00 top left hand corner .Its different than the standard G54-G59 offsets If you adjust it .01 or -.01 it will shift ALL G54 -59 settings that amount .
So if your using G54 as you offset and you put another part in and it .01 smaller jut go to
G54(00) and highlight z and type in -.01 and press input every tool will cut .01 deeper
Another way you can do it is use G52 it does the same thing.
In your program add this line before the first z move
G52 Z-.01
This will add .01 to your z depths and every tool will cut .01 deeper
Hope this helps
Tim
