I have found that using a mill area of only the faces I want to cut works much better with cavity milling. You don't have to screw around setting the depth ranges and it just works better. I also use the level based IPW so the next tool only cuts the remaining material left from the previous operation.
See the attached part
__________________ John Joyce -NC Programming Supervisor
Barnes Aerospace, Windsor CT |
