Hey Guys,
I am having the same exact issue on my '01 VF2, we have tried many times to blow out the chips and coolant but the error keeps randomly happeneing. Id like to take the limit switches (they are red) out that are behind the carousel motor panel and check them, it looks like it might be 4 bolts that hold the motor in place....is there anything else I should know before taking the motor out? Will anything fall out from inside the carousel? I figured I could check both brushes on the motor while its out. Any help would be greatly appreciated. When we called the local HAAS dealer he stated that there was a service bulletin on the red limit switches and that is probably the issue.
Thanks,
Jim |
