OKK MCV-300 , Meldas 84, parameters | | hey guys, i'm in a serious bind and i'm hoping someone out there can help. Recently i lost my battery and consequently all my parameters, Now i have a list of all of them, the problem is when i try to set them. after powering up i'll select the "DGN" key then the "ER" key then type TIT "input" then type PASET "input" then select the PA/S key.. now i can edit the "OP" frame but beyond that it wont let me edit further. when i try to edit the "LM" frame or the "BL" frame, after i type in the values and input them it will change the value on the first line to a zero and lock me out of the rest of the frame .. any help would be greatly appreciated. |
