Old 06-26-2009, 01:57 PM
Lazybum Lazybum is offline
Lazybum is on a distinguished road
Who says its PC compatible????????
The definition of compatible :
4.Computers.
a.(of software) capable of being run on another computer without change.
b.(of hardware) capable of being connected to another device without the use of special equipment or software.
5.Electronics. (of a device, signal, etc.) capable of being used with equipment in a system without the need for special modification or conversion.
6.noting a system of television in which color broadcasts can be received on ordinary sets in black and white.
–noun
7.something, as a machine or piece of electronic equipment, that is designed to perform the same tasks as another, often in the same way and using virtually identical parts, programmed instructions, etc.: Software written for one computer will probably run on its close compatibles.
Well if they call that compatible they need to go back to church as stated
software is purposely designed so a layman can not work on it. Dynagarbage wants 1200.00 for a MB 300.00 for a EXE file Yet I have found a way to retrofit the machine for about 3000.00 with a newer faster and more reliable system that uses off the shelf components and is 15 year newer technology. You can not even install an an A drive or HD without there blessings, which they will be glad to do for enough money. Its no wonder the Asian community is knocking the snot out of American companies when they use business models such as these. 3 months ago I knew not the difference between a steeper or servo, closed loop or open loop. What I have learned so far is who in the industry wants to help you succeed and those that don't care one way or the other.
Sorry for the rant.
Glenn
