I have a Kondia FV-1 with a dynapath delta 30. Durring operation it faults out with an X axis servo error. This occurs only when moving at a high feed rate or rapid in X + direction. I suspected some part of the servo motor was at fault even though the machine shows very little or gentle use. It then came to mind that it was 90degrees+ in the shop and after I turned off the machine and opened the cab it had cooled down and would run fine for 45 min or so untill it got hot again. Then the same error. I was hoping someone paying attention to this forum would be able to add some light to this issue. Does anyone know if the fans in the cab are supposed to run all the time or if they are thermostat controlled? It does not seem like the fan above the drive cards is working corectly.
Any help is appreciated! |
