You can't use a USB breakout board with Mach2. Mach2 I *think* supports usb joysticks. Art's also adding support for some other type of I/O boards, possibly USB, not sure.
Mach2 has a USB mode for running the Gecko G2002 pulse generator. But you can't send your step and direction signals through USB. Parallel port only.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
