what caused it so ill know what to look for
must be some error message, pointing to reason.
Push the button :-)
there is tool management mode on this control, and you can see exactly what tools are set and which pot they are sitting in.
if the pot is empty in deed, but it is described in OSP as is contains some tool, the alarm occurs depending on parameter setting. |
