Old 06-24-2009, 08:25 AM
Weldtutor's Avatar
Weldtutor Weldtutor is offline
Weldtutor is on a distinguished road
Arrow Torch Automatic Ignition
Originally Posted by DanOSB View Post
to incorporate a auto lighting system (instead of using a striker to start the flame
A 12 volt automotive ignition coil will work.
The system pictured has the coil & 12 V supply in the upper control panel with a high tension (spark plug) wire running to an insulated brass rod electrode gap at the torch tip.
A momentary signal to a relay (or push button) to power the 12 V supply will then provide the necessary spark for torch ignition.
