Use M94 or M94.1, especially for 3D work. When cutting aluminum, Ren, plastic or foam I'm usually in the 125-275 ipm range. I don't change my gain settings, just leave then at normal unless you want all that banging and shorter machine life.
You should also check your backlash. I adjust mine every 3 months. This does affect accuracy. |
