Originally Posted by MechanoMan The Sherline can handle this.
It is not right for the center drill to wobble. Are you sure you started it at the basic center of rotation?
I have had trouble where the tailstock isn't pointing dead center into the axis of rotation. You can kinda adjust the brass shim on the tailstock-to-rail mount.
You cannot use the tailstock with the parting tool, at least you're not *supposed* to be able to do so by the book. Because the compression causes it to collapse onto the parting tool when the last bit of material gives way. If you keep tailstock pressure minimal this may not be a problem, but the disc needs to be able to fall away.
A SteadyRest will stabilize the 5" stock for end cutting.
Make sure the tailstock is not fully retracted to the ejection position, pull back the jaws of the 3-jaw chuck so they fall below the surface, LOOSEN THE TAILSTOCK OFF THE RAIL, hold the tailstock wheel in your right hand for linear resistance and turning resistance, and *gently* tap the chuck with a hammer. It will stay.
It's not normal. Either the center drill hole was not completely on center (may have moved accidentally), or your tailstock chuck is not pointing towards center. Or your center drill sucks.
No such thing as too sharp.
The coiling "swarf" is desirable. If you are getting chips, you may be turning too fast on the motor or not feeding it fast enough to keep the coil continuous. If it's not coil-swarfing, vibration may occur.
I'm not sure why you're enlarging a previous hole by choice. The bit is more stable on one big drilling operation. |
Exactly what I was going to say, you should have band sawed that piece first then face it off on the lathe, then centered drilled!!!!
