Ger....
so you figure the max IPM will be 59?... looks like I am being limited by Mach 2...
I figured with a 1750 RPM reduced 27... gives 64.8 rpm's... each RPM gives 300mm travel.. thats 765 IPM?.... that's assuming full RPM even at half RPM I shuld still obtain 380 IPM.... do you think that is correct.?... |
