New To The CNC Machining Trade | | Hi Guys,
I have been tiring to make a part that is two sided but when I flip it to mill the second side the top cuts doesn’t line up with the bottom. I’ve tried many things and have been un successful so far.
Basically I’m using 1X1 inch 6061 bar stock what I’ve done is programmed the part form the center and mill the bottom cuts first. After the bottom is milled the finished demission’s are .760 inch basically when I flip the part and clamp it in the vise the Y axis is off. I can’t clamp the part by the un milled area because there are OD cuts for the top half, Is there an easy way to set this job up? |
