Originally Posted by jalessi Noisillator,
You will need a BOB (breakout board) other than that the G250 with provide the same stepper motor functionality. |
Who sells those? I don't see them on the Gecko site.
If you don't want to use IDC cables or connectors you may want to consider the G251 instead of the G250. |
Screw terminals are a little easier, of course, but I can work with either type. Are these two driver boards essentially the same otherwise? The G251 is said by Gecko to be a "miniarized version of the G201," whereas the G250 is described as "the drive that forms the control interface of the G540." Because of this, I just assumed there were differences other than the connector interface.
