Swede,
Thank you for the feedback and info. I did code using variables as well as an INI file. I found I had an optimization issue in my code and with the CreateWaitableTimer am now getting about 4.5 ipm. I did recode again using a for/next loop and was able to get about 26 ipm, but it did skip a few steps. My table is using all-thread with delrin nuts so I have a hard time getting over 10 ipm with the 80 oz/in. motors, so it is plenty fast for my needs. I have moved on to coding a g-code interpreter. I'm using some dxf source code that I found at
http://home.datacomm.ch/reto.knaak/dxf.html, which was a big break. I'll post the source code once I get a little further along. Attached is a screen shot.
Thanks again,
Darren
