Originally Posted by zephyr9900 Peter, if you are promoting the ACT as a Tormach alternative, you would earn some credibility by duplicating any of the demo videos from the Tormach site. A 3/4" steel plate is finished on both sides. One side is a surface cut, the second side has 0.2" removed using 1.5" diameter face mill with high positive angle inserts. would be a good place to start. Thank you.
Randy |
It is a good idea to have some actual cutting video. ACT DMC-III is not a machine to replace the Tormach. ACT DMC-III is a high precision (repeatable 0.0002") for all metals, very compact weight only 260 lb. It is movable by 2 person without using forklift and suitable for smaller precision parts.
