Old 06-17-2009, 11:22 PM
WSS's Avatar
WSS WSS is online now
WSS is on a distinguished road
A replaceable Carbide tip is perfect, you could mark AR plate and probably high carbon SS like 440C.
I want to be able to handle 3", but will usually cut .5" to 2.5" plate. One job we do fairly often is a cut on 9/16". I am hoping to utilize the plasma for this. The preheat time with oxy is the same as the cut time. Plasma would really speed it up.
If you get a chance post some photos of your retro/upgrade. The DASH system seems like it would pay for itself after awhile with saved tips! A little trick we do with oxy is to spray both inner and outer tip with anti-spatter. It really does not stop the blow back but does make cleaning easier. Can that be done with the plasma parts?
How does the dynascribe know it's location in tandem with the torch? Is it a separate screen or can it run both together as one file?
