HE DID NOT SAY HE WAS DROPPING IT! Just for your info, he said he was wanting to bend or adjust the arm. Its not uncommon to have to adjust the arm postition after some form or another when you modify for racing or off road, also for your info on oval track in not uncommon to have differant spindels on the left and right sides. For off road where a higher ground clearance is needed and done with a lift kit, the steering gear is stiil on the frame and now with the height differance sometimes you have to adjust your arms and linkage to get the wheels to turn in there proper arcs(ackerman effect)
FYI: never broke a spindel after any of the mods that where done to several differant spindels use in dirt track racing in 25 years
__________________ JEFFY |
