Old 06-16-2009, 12:09 PM
dirtdiggler dirtdiggler is offline
dirtdiggler is on a distinguished road
Thanks for your opinion and feedback. I guess I can't go wrong with either one. MeshCam seems to have some pro options but I guess I'm still on the fence because Cut3D is damn simple. I'm going to have to keep evaluating and maybe mill up one of the sample models from Cut3d and compare it with Meshcam.....As far as resolution goes, Tony Mac from Vetric said "The quality of the toolpaths calculated by Cut3D is primarily controlled by the tolerance used to create the original 3D mesh that the more accurate the STL file the more accurate the cut will be"
I'm not sure how the resolution works in MC in this regard because you have the ability to adjust the resolution prior to making a toolpath as well.
If Cut3D had the 4th axis output it would probably be a no-brainer for me to buy it.
