I have a MD3 which is the same toolchanger I think but newer control so I'm not sure how much help this is. If the toolchanger gets interrupted for whatever reason on mine you can go into diagnostics to to manually reset anything that needs to be, then when you exit diagnostics you can tell it what tool is in the spindle and press start, then it checks that tool slot is empty in the carousel. |
