Is it just a belt reduction to turn a screw? If so, then the only issue would be inertia from a larger diameter. If the pulleys are heavy, than it would take more torque to accelerate at the same speed. If they are plastic, it probably won't make much difference.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
