No you DO NOT need any 10-24V to program the VFD. That is an OPTION if you want to control it from your control software (like MACH3).
Start simple.
1. hook up the drive to the VFD
2. hook up the 220VAC to the VFD
3. program the VFD
4. start routing
See the other thread for the details of these steps.
After you get it going and you want to get fancy and run it through your control software, then you will need to purchase a driver board, and do some re-programming and some wiring - much more complex.
Start simple. |
