Old 06-09-2009, 06:25 AM
LeeWay's Avatar
LeeWay LeeWay is offline
LeeWay is on a distinguished road
I did get rid of those grinding stones that were taking up space in my shop. I tried them out after breaking into small chunks in my concrete mixer. It worked pretty well on the deburring of things on steel, however it left pitted surfaces from all the sharp points. This was 30 minutes in the mixer with just a water slurry. Served to prove a few things.
My deburring needs can quickly be taken care of with a decent machine and the correct media. Use these grinding stones as backfill for the headwalls on my driveway culvert headwalls.
I hired a guy to do this. I recently had to replace my old culvert. It was undersized and storm damage just washed it all out. I have had my fill of larger scale concrete work. Like roofing, I hire it done when I can.
Got all the parts together for the machine. Initially I was going to weld the frame using 2" x 3" angle iron. Now I think I will bolt it together instead. I may still tack it after the bolts are in place, but dowels may be a better option.
The bottom shelf eluded to in my drawings will be for holding weight. I have about 10 buckets of scrap steel sheet offcuts that would all a bunch of base weight to the frame. I use one under my grinder and it really helped that station out.
I also thought about using a paint shaker for a machine. I don't think the up and down movement would be very beneficial though. If someone has a small one though, it might be beneficial to try at least for a small aluminum finisher.
I hope to get to building the big machine this weekend. If this all works out okay, then I will scale the machine to do a smaller version for my aluminum parts.
Lee
